First post, by rolloLG
I have bought one Hori Fighting Stick Mini but suddenly found that games like Zool2 go crazy when I select joystick...
This is how MS Windows identifies the joystick:
Someone can help me? 🙁
Works great on MAME and other emulators with directions seen as DPAD, but not under DOSBox 0.74... 😢
Reply 6 of 16, by Yesterplay80
I noticed in your screenshots that the DPAD seems to be pressed to the right. Was that just coincidence or does it always show up like that?
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 7 of 16, by rolloLG
No I was pressing right to show direction detection.
I can't find a DOSBox version working with this good joystick 😢
I see DOSBox has option to select 2-4 axis... but mine is detected as: "Using joystick Controller (Fighting Stick mini 4 kai) with 5 axes, 10 buttons and 1 hat(s)"
Windows "Game Controller Settings" seems to detect the actual directional lever as the "look around" pad of a XBox controller. The cross axes (on the upper left) won't move.
Reply 9 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Try a build against SDL2. But don't ask me where to get that 😉
Yesterplay80?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
DOSBox SVN snapshot for OS X (10.4-10.14 ppc/intel 32/64bit) codesigned for gatekeeper
DOSBox SVN with SDL2 snapshot for OS X (10.7-10.14 intel 64bit) codesigned for gatekeeper
Reply 11 of 16, by AlphaPapa
Suggestions:
Can you try in the dosbox config to change the joystick type. Do one that has more than 2 axis. Also possibly use the built in dosbox mapper. unmap anything to joystick and re-setup (tedious)
Reply 12 of 16, by rolloLG
These are my settings:
jbutton_0_0 "key 305"
jbutton_0_1
jaxis_0_1-
jaxis_0_1+
jaxis_0_0-
jaxis_0_0+
jbutton_0_2
jbutton_0_3
jbutton_1_0
jbutton_1_1
jaxis_0_2-
jaxis_0_2+
jaxis_0_3-
jaxis_0_3+
jaxis_1_0-
jaxis_1_0+
jaxis_1_1-
jaxis_1_1+
jbutton_0_4
jbutton_0_5
jhat_0_0_0 "key 273"
jhat_0_0_3 "key 276"
jhat_0_0_2 "key 274"
jhat_0_0_1 "key 275"
mod_1 "key 305" "key 306"
mod_2 "key 307" "key 308"
mod_3
What should I try changing? Is there a guide?
EDIT: ok, with CTRL+F1 I can redefine controls... will try different combos....
Reply 13 of 16, by rolloLG
All right!
After A LOT of attempts I've finally found a working config! 😀
Joystick cfg (file dosbox.conf):
joysticktype=fcs
timed=false
autofire=false
swap34=false
buttonwrap=true
and remapping (Ctrl+F1) up, down, left, right, for Axis 1/2 and deleted mapping of axis 3/4 and the other (file mapper-0.74.map) as:
jbutton_0_0 "stick_0 button 0"
jbutton_0_1 "stick_0 button 1"
jaxis_0_1- "stick_0 hat 0 1"
jaxis_0_1+ "stick_0 hat 0 4"
jaxis_0_0- "stick_0 hat 0 8"
jaxis_0_0+ "stick_0 hat 0 2"
jbutton_0_2 "stick_0 button 0"
jbutton_0_3 "stick_0 button 1"
jbutton_1_0 "stick_0 button 0"
jbutton_1_1 "stick_0 button 1"
jaxis_0_2-
jaxis_0_2+
jaxis_0_3-
jaxis_0_3+
jaxis_1_0- "stick_0 hat 0 8"
jaxis_1_0+ "stick_0 hat 0 2"
jaxis_1_1- "stick_0 hat 0 1"
jaxis_1_1+ "stick_0 hat 0 4"
jbutton_0_4
jbutton_0_5
jhat_0_0_0
jhat_0_0_3
jhat_0_0_2
jhat_0_0_1
Case solved! 😎
Thank you all for the given suggestions!
P.S.
To make things even more complicated the fact that every dosbox.exe version behaved differently to axis remapping, keeping defaults without dosbox.conf modifications! Weird...
P.P.S.
https://www.dosbox.com/wiki/Mapper
«If you want to remap anything to your d-pad/hat you will have to change joysticktype=auto to joysticktype=fcs in configuration file. Maybe this will be improved in the next dosbox version.»!!
Reply 14 of 16, by Yesterplay80
rolloLG wrote:
P.P.S.
P.P.P.S.: DOSBox ECE allows mapping the dpad and all available axis even with joysticktype=auto. 😉
Reply 15 of 16, by rolloLG
BTW, where can I find all special feature options in ECE version?
I mean options like "config -set fulldouble=true" to enable vsync etc. In particular for vsync and swap stereo channels (with some games through a .BAT)
Reply 16 of 16, by Yesterplay80
All options have a short descriptions in the .conf files. You can generate a default .conf file by starting DOSBox (ECE) and entering
config -wc
This will create a new. conf file under %localappdata%\dosbox\dosbox-ECE.conf. Or directly specify the path you want the file:
config -wc <pathtofile>
