COM Interface
First post, by Guest
Is the COM Interface supported in DOSBox?
Reply 3 of 6, by Snover
From dosbox.conf:
[directserial] # directserial -- Enable serial passthrough support. # comport -- COM Port inside DOSBox. # realport -- COM Port […]
[directserial]
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
directserial=true
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
Yes, it’s my fault.
Reply 5 of 6, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
The support is limited. Direct physical access should work, but some BIOS(?) functions are not implemented yet. It was discussed here before (try to search).
CANADACOW said he would have a look on it (so *maybe* in a future version).
Anyway: what are precise errors in the program and/or DOSBOX?
Mirek
Reply 6 of 6, by caleb99
I have this old program that I use and it uses an external modem to dial out to other machines. When I try to run it in DOSBox it tells me that there is no com port. I have the modem attached to com 1 and dosbox setup with directserial on com one, but the program still can't seem to find the com port.
