First post, by Jin X
Hello.
When I'm executing a program with MIDI sound (playing via MPU-401 ports 330h/331h) I hear the sound.
But when I'm trying to capture the movie (Ctrl+Alt+F5) the sound is not recorded.
I.e. it is played but not recorded.
Why? And how can I resolve this problem?
p.s. When I use audio editor (with output sound capturing) I can record this sound.
Reply 2 of 2, by junglemontana
Jin X wrote on 2020-04-11, 11:19:
Hello. When I'm executing a program with MIDI sound (playing via MPU-401 ports 330h/331h) I hear the sound. But when I'm trying […]
Hello.
You can either use a stand-alone capture software such as OBS, or capture the video using the internal recorder and audio using an external audio recorder and merge these in a video editor.
Or, check if there are 3rd-party modifications for DOSbox that implement a MIDI player internally. I don't know if there are or not.
