First post, by WarMasterXX
I own an official copy of the game, dumped it to iso, and have it mounted via imgmount, yet this stupid message comes up every time I try to start the game!
Regular Batman Forever is set up the same way and didn't have any issues. Is there a way to fix this? I hope so, because I can't find a crack for this game anywhere!
Oh and another thing: An ISO of the game I downloaded from an abandonware site before I bought my legit copy never had this issue and ran perfectly, so what gives?
Reply 3 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You should make a CUE/BIN format image of the disc, as the ISO format can't contain audio tracks. Perhaps you use "ISO" to refer to any kind of disc image, but please do not do that as it can be understood as referring to the ISO format.
If you did make an ISO format image then the game will likely fail to recognize the disc because the audio tracks are absent. If you made a CUE/BIN format image then there is probably some issue with the CUE file, and you can post its contents here for review.
Reply 4 of 6, by WarMasterXX
ripsaw8080 wrote on 2021-06-30, 18:32:
Sorry for the confusion, I did make it into a BIN/CUE:
FILE "BFARCADE.BIN" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 02:07:22
TRACK 03 AUDIO
INDEX 01 04:25:71
TRACK 04 AUDIO
INDEX 01 08:29:18
TRACK 05 AUDIO
INDEX 01 12:58:17
TRACK 06 AUDIO
INDEX 01 17:28:28
TRACK 07 AUDIO
INDEX 01 26:19:32
TRACK 08 AUDIO
INDEX 01 31:53:55
TRACK 09 AUDIO
INDEX 01 36:41:74
TRACK 10 AUDIO
INDEX 01 37:57:35
TRACK 11 AUDIO
INDEX 01 43:26:59
TRACK 12 AUDIO
INDEX 01 44:39:48
TRACK 13 AUDIO
INDEX 01 48:02:27
TRACK 14 AUDIO
INDEX 01 52:20:23
Reply 5 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The CUE looks okay. However, some games check the start time and length of audio tracks as a kind of CD-check, and the imaging software used to make the image might have not recorded the specific timing the game looks for. Are there different times in this CUE compared to ones you used previously?
Reply 6 of 6, by WarMasterXX
Here's the CUE from the abandonware ISO:
FILE "BATMANAR.bin" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
TRACK 02 AUDIO
INDEX 01 02:05:47
TRACK 03 AUDIO
INDEX 01 04:24:21
TRACK 04 AUDIO
INDEX 01 08:27:43
TRACK 05 AUDIO
INDEX 01 12:56:42
TRACK 06 AUDIO
INDEX 01 17:26:53
TRACK 07 AUDIO
INDEX 01 26:17:57
TRACK 08 AUDIO
INDEX 01 31:52:05
TRACK 09 AUDIO
INDEX 01 36:40:24
TRACK 10 AUDIO
INDEX 01 37:55:60
TRACK 11 AUDIO
INDEX 01 43:25:09
TRACK 12 AUDIO
INDEX 01 44:37:73
TRACK 13 AUDIO
INDEX 01 48:00:52
TRACK 14 AUDIO
INDEX 01 52:18:48
