First post, by GeorgeC
I've mounted my drive and started my DOS program successfully. Now I need to copy a file to disk but it lists drives from A to Z it doesn't recognise any drive but will save a file to the mounted drive/folder. When I run the same program on a native DOS computer it lists only the existing drives and I can scroll through and save to whatever drive/folder I wish. When I try to retrieve a file from disk DOSBox lists A to Z but it won't recognize any of them and I can't retrieve a file at all. On the native DOS machine it lists only the existing drives and folders and I can load the file I wish wherever it is. I have tried using Set Path in DOSBox also.
Where am I going wrong?
George
