Blank Screen
First post, by nesianstyles
Hi,
I must appologise if this is has been answered before but I've been searching the forum for a while and I can't find the answer. I've got Windows 98 and When I run Dosbox (Latest Version) it opens a MS-Dos Prompt Window and Another One Pops Up with the mouse working, which I believe is the dos box menu but it is blank, nothing is there except black. I'm totally new to dos box, but I have worked with dos before. I've also read through the read-me and found that no help.
Thanks, it means allot
Nesianstyles
Reply 1 of 24, by eL_PuSHeR
Rank Moderator
Moderator
Check your dosbox.conf file. Edit it with notepad and search for a line containing output=
change it to output=surface.
If it doesn't work yet, try updating video drivers.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 24, by eL_PuSHeR
Rank Moderator
Moderator
Well you could try two things:
1s) Updating your video drivers.
For ATi cards, look here.
For nVIDIA cards, look here.
2nd) You could try replacing SDL.DLL (Simple DirectMedia Layer) for an updated (or even older) version, to see if that makes a difference. Download SDL.DLL versions here.
Good luck!
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 24, by `Moe`
That sounds perfectly OK to me. Dosbox doesn't have any menu. What you see is dosbox working just fine. Read the readme to see what you can/must type at the dos prompt.
If you want a menu and a graphical frontend, download D-Fend, you can find it via dosbox's homepage.
Reply 8 of 24, by `Moe`
The "MS-DOS prompt window" sounds like the dosbox window to me, while the second, black window sounds like the console window that appears with some CVS builds. Just my interpretation, hard to say what is what without details/text.
Reply 10 of 24, by user222
Try the "SDL_VIDEODRIVER=windib" variable to see if it works. You could use a batch file if you only want the variable temporarily.
the batch file should look like:
set sdl_videodriver=windib
cd "C:\Program Files\DOSBox-0.63"
dosbox.exe
Reply 12 of 24, by `Moe`
Did you upgrade dosbox and are using the same config as before?
I now recall I once had the same problem, and it was caused by some option which had changed name. No idea what it was, but after creating a completely new config file, it worked again.
Reply 14 of 24, by eL_PuSHeR
Rank Moderator
Moderator
We still don't know what videocard and/or driver version are you using... 😐
Intel i7 5960X
8 GB DDR4 (2100)
Reply 16 of 24, by HunterZ
Phillips 107S is your monitor, and ATI 3D Rage Pro is your video card. You never told us whether you got the newest drivers or not - you can get them here: https://support.ati.com/ics/support/default.a … dge&folderID=27
It would probably be a good idea to make sure you have the latest version of DirectX installed as well.
Reply 18 of 24, by DosFreak
Hmmm, some kind of incompatibility between the ancient 3D Rage and SDL.....
Have you tried any of the other output modes...well come to think of it the only other one that would apply to that video card would be Overlay, if the 3D Rage can even do that.
So try Output=overlay
According to this website: http://www.wavestore.com/graphicslist.html the chipset supports it. Where did you get the drivers for the card from?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 19 of 24, by nesianstyles
Same Result. You may like to know, since I updated the drivers it says "Rage Pro Turbo AGP". I got the new drivers here: https://support.ati.com/ics/support/KBAnswer. … questionID=1307
