First post, by Cosmin
Hello all!
I am trying to create a batch file that run DOSBox.exe, and then send input keys (such that dosbox will think that I pressed a certain key). I created it and it works perfectly with notepad.exe.
My problem is that when I go to change the pathname to open DOSBox.exe instead of notepad.exe, it gives me an error:
ERROR: Cannot find the specified file
ERROR CODE: 80070002
Here the code:
(echo with createobject^("wscript.shell"^)
echo .run "C:\Program Files (x86)\DOSBox-0.74-3\DOSBox.exe" <-------------if i change this with "notepad.exe", it works
echo wscript.sleep 2000
echo .sendkeys "MOUNT D: D:\"
echo .sendkeys "{enter}"
echo wscript.sleep 1000
echo .sendkeys "D:"
echo .sendkeys "DIR"
echo .sendkeys "%%{F4}"
echo end with) > %temp%\sk.vbs
start /w %temp%\sk.vbs
    66.36 KiB
    Windows script host error
Reply 1 of 7, by _Rob
You can have a (possibly per-game) dosbox config file with an [autoexec] section where you do the steps such as MOUNT or change drive or run DIR. No need to use an external script.
e.g.
[autoexec]
MOUNT D: D:\
D:
DIR
In addition some dosbox forks (e.g. DOSBox-X or -staging) have support for AUTOTYPE which can be used to perform scripted keyboard entries into a running DOS program.
Reply 3 of 7, by Stretch
Replacing the 2nd line with the following code may work also
echo .run Chr(34) & "C:\Program Files (x86)\DOSBox-0.74-3\DOSBox.exe" & Chr(34)
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 4 of 7, by Cosmin
Stretch wrote on 2022-03-05, 20:17:
Replacing the 2nd line with the following code may work also […]
That works! Now it opens DOSBox.exe but does not send input keys. After run DOSBox.exe it stops and does not execute the rest of the commands. Then, if I manually close the tab, the commands continue, and it prints an error like in the photo:
    27.08 KiB
    runs dosbox but does not send any input keys
    31.13 KiB
    the error after closing dosbox tab manually
Reply 5 of 7, by Stretch
I almost had it working except the mount command didn't work for me. You may want to consider autohotkey or autoit instead.
echo .run "C:\PROGRA~2\DOSBox-0.74-3\DOSBox.exe"
echo .AppActivate "DOSBox 0.74-3"
echo wscript.sleep 250
echo .sendkeys "MOUNT D D:\"
echo .sendkeys "D:"
Reply 6 of 7, by Cosmin
Thank you so much!
So I don't know why it can't send long strings.
Using this :
It print only "MOUNT D" then it stops.
So, i separated the string into multiple sendkeys and then it works perfectly.
echo .sendkeys "MOUNT "
echo .sendkeys "D "
echo .sendkeys "D:\"
Reply 7 of 7, by jmarsh
This is a very roundabout (and hacky) way of doing things (using an external program to send keypresses to the DOSBox application) when DOSBox already supports individual config files and startup commands. Not to mention batch files.
A case where everything looks like a nail when you're holding a hammer, I guess.
