First post, by jal
- Oldbie
I recently purchased an SAAYM sound card from TexElec, which sports two SAA1099s and should be Gameblaster / CM/S compatible. However, I noticed after writing a quick test program that in DOSBox the notes play a lot higher (8 halfnotes to be precise). Is this a known inaccuracy? If not, is there any way to properly test whether the problem lies with DOSBox or with the SAAYM? (I wouldn't expect the SAAYM is too blame, it seems to use the right clock frequency.)
JAL
