First post, by an24na
Hi, how do you mount a game in Windows 3.1 on Dosbox please?
Same way you mount an image in Dosbox, but add your mount command at the end of the conf file. You can't mount while 3.1 is running.
feda wrote on 2023-08-17, 07:40:You can't mount while 3.1 is running.
Yes, you can. Just create a batch script with the necessary commands and run the script within Windows 3.1.
Hi, please can you give me a link to a tutorial or video to do this?
zirkoni wrote on 2023-08-17, 15:04:feda wrote on 2023-08-17, 07:40:You can't mount while 3.1 is running.
Oh, right! IMGMOUNTing this way works. Just MOUNTing a local folder doesn't.
an24na wrote on 2023-08-17, 15:32:Hi, please can you give me a link to a tutorial or video to do this?
The wiki and the manual explain this stuff.
https://www.dosbox.com/wiki/IMGMOUNT
