First post, by 7F20
I'm having trouble with my Paths. I am trying out different file system browsers in dosbox, and I want to have multiple available at the same time. I have this line in config:
set PATH=Z:\;C:\dn151;C:\Utilities\zdir21;C:\Utilities\doszip-3.66Win64\dz
I am able to access the first path, C:\dn151 from anywhere, but not the other two. I believe I'm following the same syntax for all of them?
Just to be clear, my actual C: drive is mounted as C:\games, and all these other paths are behind that. I tried adding the \games to it also and that did not work for any directory, so I'm assuming that DOSBox is only looking for those variables after the point at which C: is mounted.
Thanks
