dosbox for s60 (symbian) first results
Reply 120 of 197, by DanILD
Does it work on nokia 5800?????
Reply 121 of 197, by Kalandor
pizzulicchio wrote:
Perfect! IT WORKS!!! Now the "enter" key is fully working […]
The screen size seems zoomed but now it's readable!
Now the only problem seems to be the audio that isn't clear!
I think it's better to disable audio when possible. I think you'll save some CPU cycles if you launchg games with audio disabled.
I think it would run.. How is entirely different matter. But we are all waiting for the dynamic-core release 😀
Reply 122 of 197, by Qbix
Rank DOSBox Author
DOSBox Author
There are more projects on sourceforge that are ports of dosbox. However they all seem to die really fast.
So if you just want to have the source available (if you don't have time to develop it anymore) then this forum is just as fine as a dorment sourceforge project.
There are a few ports which already implemented a overlay keyboard I think. For example the n0p port.
Water flows down the stream
Reply 123 of 197, by kolijoco
@qbix,
point taken...
i'd prefer taking it to sf to keep development (even if not by myself) "centeralized", and hopefully prevent too many multiple versions and instances from floating around.
the ultimate goal is still to facilitate a merge into the official dosbox tree, which right now would take many-many ifdef-s, and with the symbian-side "clarity" lacking at this point i couldn't do it with a clear conscience.
so if there are no serious objections, i'll try to take it to sf for now...
Reply 125 of 197, by abdelrahman
i have a 5800 device i already downloaded the dosbox_s60 what else should i get to run this windows on my device
and please does it have any problems ???
thank u
i used to be my own protection but not now cause my path has lost direction somehow
Reply 126 of 197, by abdelrahman
is there a special virsion for 5800 i downloaded the virsion s60 3
but it never starts help
Reply 127 of 197, by Kalandor
thank u
You should instal dependencies as well as dosbox sis file.
Reply 128 of 197, by abdelrahman
please where can i find this
and is it normal?? this dosbox doesn't start when i click on it
Reply 129 of 197, by gregd72002
In here: *removed by Qbix*
Ask all the questions in there as well.
Link contains copyrighted software
Reply 130 of 197, by kolijoco
my carbide (ide) just stopped working. anyway, till i get that revived, and sf.net approves the project (i put the request in), thought i'd let the faithful experiment with the last binary i had built.
changes (quite a few things, read the NEW readme, and the comments in the attached NEW conf file!!!):
- dynamic core!!! beware, it needs (yet more) ram
- pagable high res mode
- i've obsoleted the orientation setting. dosbox should now always start in landscape mode.
thats about it. please refrain from posting requests until the project opens up on sf...
have a happy weekend!
edit: go to sourforge to download (s60dosbox package)
https://sourceforge.net/projects/s60dosbox
Reply 131 of 197, by Andy1210
Thank you! 😀 You are the Best 😁
Screen Zoom working perfectly 😁 in page mode
windows not working 😁 after win boot screen->dosbox quit
Supaplex work great 😀
streetrod too
I test it yet 😀
only for kolijoco: /közzétettem nokiaprogramokon is 😀 ahogy már eddigis tettem 😁 /
Reply 132 of 197, by Obi-Wahn
Well, there is already an Symbian Dosbox project on sf.net But, ... i think, your project could be a bit better! The other project has no content! 😉
Reply 133 of 197, by Freddo
Not to mention that it's been dead for many years.
Reply 134 of 197, by Octane
Hello! Great work you have done sir. I been waiting for a port to s60 for a long time!! 😁!!
I have a question here about keymapping. I'm stuck in a game because I need to use the dash ( - ) in a game and I can't figure out how to map it correctly. Is there a way I can map the dash to the * or # key?
Thanks in advance and again, great work.
Edit: Got it now! enjoying some X-COM now 😁!!!!!!!
Reply 135 of 197, by kolijoco
i'm aware of the existing symbian dosbox project. i have contacted the admin, and he agreed to the takeover...
Reply 136 of 197, by mjlaris
I have an E71 and I just installed DOSbox and it's working fine. I'd like to install Windows 3.1 but I don't know how. Can someone here point me in the right direction? Thanks,
Mark
Reply 137 of 197, by pepe55
Thanks ,new version is good but I think that cd rom support is important because some games not working now .
And I have one question is there any way to use keymap like on PSP inputmap in bat files for example
keen5/keen5.bat - INPUTMAP key_1 "key 49"
INPUTMAP key_2 "key 50"
INPUTMAP key_3 "key 51"
INPUTMAP key_4 "key 52"
INPUTMAP key_5 "key 53"
INPUTMAP key_6 "key 54"
INPUTMAP exec keen5e
Reply 138 of 197, by Eimer
Do this play in Nokia 6600 ?
Reply 139 of 197, by n1c072
Hi, thanks for the great porting...
Unfortunately the last build does not works on my N95 8gb
Screen goes landscape but nothing happens and the app immediately closes!
Thanks for your help
