First post, by Snover
Snover
Offline
- l33t++
Compiling...
cl : Command line warning D4002 : ignoring unknown option '/QxMi'
cl : Command line warning D4002 : ignoring unknown option '/bQipo'
dosbox.cpp
Generating Code...
Compiling...
dirent.c
Generating Code...
Compiling...
fpu.cpp
c:\SBIN\DOSBox\cvs\dosbox\src\fpu\fpu_instructions.h(306) : error C2668: 'log' : ambiguous call to overloaded function
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(612): could be 'long double log(long double)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(564): or 'float log(float)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(193): or 'double log(double)'
while trying to match the argument list '(int)'
shell_misc.cpp
shell_cmds.cpp
shell_batch.cpp
\SBIN\DOSBox\cvs\dosbox\src\shell\shell_batch.cpp(80) : warning C4018: '<' : signed/unsigned mismatch
shell.cpp
\SBIN\DOSBox\cvs\dosbox\src\shell\shell.cpp(115) : warning C4101: 'old_in' : unreferenced local variable
\SBIN\DOSBox\cvs\dosbox\src\shell\shell.cpp(115) : warning C4101: 'old_out' : unreferenced local variable
support.cpp
setup.cpp
\SBIN\DOSBox\cvs\dosbox\src\misc\setup.cpp(318) : warning C4018: '>' : signed/unsigned mismatch
programs.cpp
messages.cpp
xms.cpp
mouse.cpp
ems.cpp
\SBIN\DOSBox\cvs\dosbox\src\ints\ems.cpp(359) : warning C4018: '<' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\ints\ems.cpp(370) : warning C4018: '<' : signed/unsigned mismatch
dpmi.cpp
\SBIN\DOSBox\cvs\dosbox\src\ints\dpmi.cpp(1354) : warning C4244: '=' : conversion from 'PhysPt' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\ints\dpmi.cpp(1355) : warning C4244: '=' : conversion from 'PhysPt' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\ints\dpmi.cpp(2590) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\ints\dpmi.cpp(2605) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
bios_keyboard.cpp
bios_disk.cpp
bios.cpp
int10_vesa.cpp
int10_put_pixel.cpp
int10_pal.cpp
int10_modes.cpp
Generating Code...
Compiling...
int10_misc.cpp
int10_memory.cpp
int10_char.cpp
int10.cpp
timer.cpp
tandy_sound.cpp
softmodem.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(478) : error C2668: 'abs' : ambiguous call to overloaded function
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(584): could be 'long double abs(long double)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(536): or 'float abs(float)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(530): or 'double abs(double)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(528): or 'long abs(long)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\stdlib.h(265): or 'int abs(int)'
while trying to match the argument list '(unsigned long)'
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(482) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(483) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(544) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(545) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(561) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\hardware\softmodem.cpp(562) : warning C4244: '+=' : conversion from 'double' to 'float', possible loss of data
serialport.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\serialport.cpp(159) : warning C4018: '>=' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\hardware\serialport.cpp(159) : warning C4018: '<=' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\hardware\serialport.cpp(255) : warning C4018: '>=' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\hardware\serialport.cpp(255) : warning C4018: '<=' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\hardware\serialport.cpp(405) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
sblaster.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\sblaster.cpp(453) : warning C4554: '&' : check operator precedence for possible error; use parentheses to clarify precedence
pic.cpp
pcspeaker.cpp
mpu401.cpp
mixer.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\mixer.cpp(233) : warning C4018: '<' : signed/unsigned mismatch
memory.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\memory.cpp(603) : warning C4018: '<' : signed/unsigned mismatch
keyboard.cpp
joystick.cpp
iohandler.cpp
hardware.cpp
gus.cpp
gameblaster.cpp
Generating Code...
Compiling...
dma.cpp
disney.cpp
cmos.cpp
\SBIN\DOSBox\cvs\dosbox\src\hardware\cmos.cpp(89) : warning C4554: '&' : check operator precedence for possible error; use parentheses to clarify precedence
adlib.cpp
c:\SBIN\DOSBox\cvs\dosbox\src\hardware\fmopl.c(1121) : error C2666: 'pow' : 7 overloads have similar conversions
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(620): could be 'long double pow(long double,int)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(618): or 'long double pow(long double,long double)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(572): or 'float pow(float,int)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(570): or 'float pow(float,float)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(534): or 'double pow(int,int)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(532): or 'double pow(double,int)'
c:\SBIN\Microsoft Visual Studio .NET 2003\Vc7\include\math.h(195): or 'double pow(double,double)'
while trying to match the argument list '(int, double)'
c:\SBIN\DOSBox\cvs\dosbox\src\hardware\fmopl.c(1161) : error C2668: 'log' : ambiguous call to overloaded function
c:\SBIN\DOSBox\cvs\dosbox\src\hardware\fmopl.c(1163) : error C2668: 'log' : ambiguous call to overloaded function
vga_seq.cpp
vga_misc.cpp
vga_memory.cpp
vga_gfx.cpp
vga_draw.cpp
vga_dac.cpp
vga_crtc.cpp
vga_attr.cpp
vga.cpp
sdlmain.cpp
render.cpp
midi.cpp
dos_tables.cpp
dos_programs.cpp
dos_mscdex.cpp
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(271) : warning C4244: '=' : conversion from 'Bit16u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(342) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(343) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(344) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(514) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(515) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_mscdex.cpp(516) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
dos_misc.cpp
Generating Code...
Compiling...
dos_memory.cpp
dos_ioctl.cpp
dos_files.cpp
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_files.cpp(406) : warning C4244: 'argument' : conversion from 'Bit16u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\dos_files.cpp(699) : warning C4244: 'argument' : conversion from 'Bit16u' to 'Bit8u', possible loss of data
dos_execute.cpp
dos_devices.cpp
dos_classes.cpp
dos.cpp
cdrom_ioctl_win32.cpp
cdrom_aspi_win32.cpp
cdrom.cpp
drives.cpp
drive_virtual.cpp
drive_local.cpp
drive_cache.cpp
\SBIN\DOSBox\cvs\dosbox\src\dos\drive_cache.cpp(128) : warning C4244: 'return' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\dos\drive_cache.cpp(208) : warning C4018: '<=' : signed/unsigned mismatch
\SBIN\DOSBox\cvs\dosbox\src\dos\drive_cache.cpp(311) : warning C4018: '<' : signed/unsigned mismatch
debug_win32.cpp
debug_gui.cpp
debug_disasm.cpp
debug.cpp
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(128) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(790) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(791) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(792) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(793) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(794) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(795) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(796) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(797) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(798) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(799) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(800) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(801) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(802) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(803) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(804) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(827) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(830) : warning C4244: 'argument' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(837) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(882) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(902) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(903) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(924) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(937) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(947) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(970) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(976) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(987) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(996) : warning C4244: 'initializing' : conversion from 'Bit32u' to 'Bit8u', possible loss of data
\SBIN\DOSBox\cvs\dosbox\src\debug\debug.cpp(1099) : warning C4244: '=' : conversion from 'Bit32u' to 'Bit16u', possible loss of data
slow_16.cpp
paging.cpp
Generating Code...
Compiling...
modrm.cpp
flags.cpp
cpu.cpp
core_full.cpp
callback.cpp
Generating Code...
c:\sbin\dosbox\cvs\dosbox\src\cpu\cpu.cpp(404) : warning C4715: 'CPU_CALL' : not all control paths return a value
Yes, it’s my fault.
