First post, by apollo16
The last version of DosBox don't respect "Hidden and System" attributes of files infact they are visible also if their attributes are ON, infact under Win2000 these files are not visible but in DOS Box are visible and it is wrong!!
For this reason some program as my IBM Filing Assistsant 2.0 that verify
if exist its file "File.sys" in root and verify if its attributes Hidden & System are set to on, don't run and show only a blue screen.
I suggest you to improve the program adding the internal command "ATTRIB" in order to modify the file attributes as user wants.
Best Regards
Andrea
