NEWS: Dosbox with ADlib OPL2 grabbing feature
First post, by Borg Number One
Great news for everybody who wants to
grab Adlib Data(no Wave/PCM-Data) and hears good old adlib tunes from games which use encrypted or packed game files and tunes which could not ripped until now
(e.g. some or some more Lemmings games , Pixel Painters Games: Electranoid Xatax....etc...etc....).
I love Adlib Music but "RAC"(RDOS Adlib Catcher) by "Roman Dolejsi" does only work on 368 and lower and this is/was a huge problem.
Many Games only work with a CPU higher than a 386 and that was really bad for RAC again. Crashing the whole system was the result.
In this way I asked " Roman Dolejsi " if he could add an "Adlib-RAW-Data-grabbing-feature" to dosbox and he did it.
This slightly modified source contains an
"adlib raw data capture engine" which stores each OPL2/Adlib acces to a file which can be played with Roman Dolejsi's "RDOSPLAY" or Peter Simon's "ADplug/ADPLAY".
Now many online chiptunes pages can improove/complete their archives too.
advantage is:
The file is very small because it only contains OPL2/Adlib commands and no PCM-Data
Here are the sources:
http://www.winamp5.de.tt/dosbox-0.61-adlib-grabbing.rar
or
http://mitglied.lycos.de/borgnumberone/dosbox … ib-grabbing.rar
Well there is a small problem:
Roman only has Linux and I only have VC++6 and so we cannot "produce"/compile the win32 version of that special adlib-grabbing-dosbox.
Is there anybody which could built the win32 Version?
Reply 1 of 30, by Predator
rac does work under dosbox cvs with a special config setting, search the forums by "adlib" or something 😁
Don't be so hard
Reply 2 of 30, by priestlyboy
Neither of the links above work for me Borg Number One. Please fix this...
Ieremiou
Helping Debug DOSBox.
Reply 5 of 30, by oneirotekt
Wow, fantastic! I will definitely check this out!
Reply 6 of 30, by Alkarion
When compiling the source with adlib-grabbing, I get the following errors:
sdlmain.cpp: In function `void GFX_SetSize(unsigned int, unsigned int, unsigned
int, double, double, void (*)())':
sdlmain.cpp:337: `glPixelDataRangeNV' undeclared (first use this function)
sdlmain.cpp:337: (Each undeclared identifier is reported only once for each
function it appears in.)
Do I need a special version of SDL? Tried with 1.2.6 and 1.2.7..
Reply 7 of 30, by taiken7
./configure --disable-opengl
From what Ive briefly scanned, from command line add the suffix
-adlib-grab-file <filename>
Not had much luck recording Mortal Kombat / Troddlers midi, but am rather busy at the moment to play too much.
For the curious, yes AVI does have support for midi extensions .. (hint)
Reply 8 of 30, by Rufoo
Could someone offer some more specifics regarding this Adlib grabbing version. I followed that link but there was no detail regarding usage of the file.
Perhaps I overlooked something. However, I have a domain name which is just collecting dust at the moment and would like to start a comprehensive Adlib archive.
Does the adlib grabbing version of Dosbox also allow EMS to be enabled? RAC works fine in the latest CVS but the EMS restriction places a bit of a chokehold on things.
If anyone could explain the usage of the Adlib Grabbing Version of Dosbox and if it can grab with EMS enabled that would be fantastic. And if it helps, I am using Windows XP so I'll be using a Win32 build.
Reply 9 of 30, by robertmo
The next dosboxcvs will have adlib grabbing feature when you press Ctrl-Alt-F7
Reply 10 of 30, by Rufoo
Alas that one is not avaliable yet I take it? I'm currently using the Happy 4th July version.
Reply 11 of 30, by Alkarion
The captured Adlib files now bear the extension ".dro". What is the appropriate playback software for this format?
Reply 12 of 30, by Harekiet
Rank DOSBox Author
DOSBox Author
See if you can get an adplug cvs build since there's a new driver for the .dro files in there.
Reply 13 of 30, by Rufoo
Thanks robertmo, I got the latest July 14 build and it captures the files. 😀
But the .dro files are completely alien to Adplug 1.5 for Winamp. I also read the Adplug CVS changes but have no idea about compiling, if anyone manages to compile the latest Adplug CVS for Winamp or DOS could they please inform me?
I have purchased a domain name http://www.darkmartin.com and am planning to buy webspace tomorrow to start an Adlib Archive site.
Reply 14 of 30, by Alkarion
Did anyone have any luck with compiling the Adplug CVS with MingW? I get an error concerning the docs.
Reply 15 of 30, by oneirotekt
There are already two adlib archives, here and here, and this site has some adlib files as well.
Reply 16 of 30, by Rufoo
Thanks for the info but I'm familiar with all three of those sites.
I wish to start my own site, otherwise I wouldn't have invested in a domain name. This is part of the scene which I can contribute a wealth of stuff to and all I really need is some help with playback of the .dro files.
But thanks for the tip anyway.
Reply 17 of 30, by Alkarion
This archives can hardly be called exhaustive. There is still need for a good PC game adlib archive.
Reply 18 of 30, by Rufoo
I'm with you on that. Even your classic bread and butter games like the later Keen series aren't covered yet.
No disrespect to the fine work from those sites, but there is a need for a archive with a broad range.
Reply 19 of 30, by Harekiet
Rank DOSBox Author
DOSBox Author
Yeh compiling adplug and the winamp plugin ain't exactly the easiest things around it seems. Oh well since i'm in a nice mood 😀
