First post, by Anonymous MOS
I'm having to use Visual Studio Express 2017 because I can't find 2008 or 2010, but I don't think that's the problem.
While trying to compile zlib and libpng I'm getting errors like these:
"1>------ Rebuild All started: Project: zlib, Configuration: Release Library Win32 ------
1>adler32.c
1>d:\!!!development\dosbox\zlib-1.2.5\zconf.h(364): fatal error C1083: Cannot open include file: 'sys/types.h': No such file or directory"
These continue with a lot of .c files, I also have this error:
3>------ Rebuild All started: Project: libpng, Configuration: Release Library Win32 ------
3>png.c
3>d:\!!!development\dosbox\lpng169\pngpriv.h(44): fatal error C1083: Cannot open include file: 'stdlib.h': No such file or directory
3>Done building project "libpng.vcxproj" -- FAILED.
Thanks for any help. 😀
__________________________________________
Alienware Aurora R7
Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
16 Gigs RAM
NVIDIA GeForce GTX 1070
Windows 11 Home, 64-bit
Reply 1 of 14, by gandhig
You could try the MinGW build environment(pretty simple if you follow the wiki), as there seems to be some issues in compiling DOSBox using VS 2017. Don't forget to apply this patch.
Dosbox SVN r4019 + savestates Build (Alpha)
1st thread & the only one related to the forum(?)...warning about modern-retro combo
Dead, but, Personal Favourite
Replacement for Candy Crush...Train the Brain
Reply 2 of 14, by Anonymous MOS
Thanks for the heads up. I've never compiled anything before, so any info is great! I'll try to put the patch in there too. Didn't know there was a problem before. 😀
Alienware Aurora R7
16 Gigs RAM
Reply 3 of 14, by Anonymous MOS
Finally got around to working on compiling DOSBox. Now, what exactly does this patch do, and where in the compilation process on the wiki should I incorporate it? 😀
Thanks!
Alienware Aurora R7
16 Gigs RAM
Reply 4 of 14, by Anonymous MOS
I've compiled my first SVN build, but neither video recording or screenshots work. I used the guide here: https://www.dosbox.com/wiki/Building_DOSBox_with_MinGW
I haven't checked IPX/modem yet.
edit
Network seems to work.
Found one error:
$ make install
make install-am
make[1]: Entering directory `/home/ranth/libpng-1.6.18'
depbase=`echo png.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/sh ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -g -O2 -MT png.lo -MD -MP -MF $depbase.Tpo -c -o png.lo png.c &&\
mv -f $depbase.Tpo $depbase.Plo
libtool: compile: gcc -DHAVE_CONFIG_H -I. -g -O2 -MT png.lo -MD -MP -MF .deps/png.Tpo -c png.c -o png.o
In file included from pngpriv.h:70:0,
from png.c:14:
pnglibconf.h:200:54: error: expected identifier or '(' before '-' token
0
In file included from png.h:485:0,
from pngpriv.h:297,
from png.c:14:
pngconf.h:522:9: error: unknown type name 'ptrdiff_t'
typedef ptrdiff_t png_ptrdiff_t;
In file included from png.c:14:0:
pngpriv.h:804:21: error: operator '!=' has no left operand
#if PNG_ZLIB_VERNUM != 0 && PNG_ZLIB_VERNUM != ZLIB_VERNUM
make[1]: *** [png.lo] Error 1
make[1]: Leaving directory `/home/ranth/libpng-1.6.18'
make: *** [install] Error 2
Alienware Aurora R7
16 Gigs RAM
Reply 5 of 14, by gandhig
Thanks!
There is a file (pnglibconf.h) which gets automatically generated during the compilation of 'libpng', albeit with some issues. The issue can be fixed by applying the patch posted by Yesterplay80 to the pnglibconf.h file located in 'libpng-1.6.18' directory.
However if you are not comfortable with applying a patch, the issue can be corrected manually too. Please refer this post for details.
Reply 6 of 14, by Anonymous MOS
Looks like you can't compile this whole project with VS2010 Express anyway. The tutorial is at: http://nerdlypleasures.blogspot.com/2014/03/t … x-svn-with.html .
When you get to SDL-net it says " SDL_net requires the SDL libraries, which is why we compiled the SDL libraries first. Like with SDL, you will need to unzip the VisualC.zip file and convert the solution file SDL_net.sln. Set SDL_net to Release in the Configuration Properties.
Open the SDL_net properties page, set the Configuration Type to Static library (.lib) and then click on VC++ Directories. For the Include Directories, you need to add the directory containing the SDL Include files. They can be typically found here : \Project\SDL-1.2.14 Next you need to add the directories containing the SDL Library files. These are \Project\SDL-1.2.14\VisualC\SDL\Release and \Project\SDL-1.2.14\VisualC\SDLmain\Release. You need to add both. After you have done all this, you can exit the properties window and press F7 to compile. You should end up with sdl_net.lib. "
But I end up getting this "
1>------ Build started: Project: SDL_net, Configuration: Release Win32 ------
1>Version.rc(10): fatal error RC1015: cannot open include file 'afxres.h'.
1>
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped =========="
Now, I've read that this is because the Express version of VS2010 doesn't come with Microsoft Foundation Classes for C++.
If this is true, the tutorial is completely incorrect and can't be completed with the Express version.
Anyone know?
Also, thanks for all of your help Gandhig. 😀
Alienware Aurora R7
16 Gigs RAM
Reply 7 of 14, by zirkoni
Ranthalion75 wrote:
Anyone know?
SDL_net doesn't use the MFC libraries. You should be able to just replace #include "afxres.h" with #include "windows.h"
https://youtube.com/@zirkoni42
Reply 8 of 14, by Anonymous MOS
zirkoni wrote:
Ranthalion75 wrote:
Anyone know?
Awesome! That's what I had hoped! 😀
Thanks, Zirkoni!
Alienware Aurora R7
16 Gigs RAM
Reply 9 of 14, by Anonymous MOS
Okay, everything worked up until compiling DOSBox itself. I'm not compiling this with debugging, so I don't think I need the curses.lib file. It errs out with this:
1> Generating Code...
1>LINK : fatal error LNK1181: cannot open input file 'curses.lib'
How do I get around this?
Thanks for all the help so far, guys!
Alienware Aurora R7
16 Gigs RAM
Reply 10 of 14, by zirkoni
Open the project settings, go to the linker settings and remove curses.lib from dependencies.
Reply 11 of 14, by Anonymous MOS
Thanks, everyone!
I finally got it to compile, but I get "Failed to create ddraw surface, back to normal surface." when I load my build.
Which part do I need to fix and recompile?
Alienware Aurora R7
16 Gigs RAM
Reply 12 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
just use the sdl.dll from 0.74 with your executable
Water flows down the stream
Reply 13 of 14, by Yesterplay80
Or the one from my build, if you want it in version 1.2.15. Doesn't make a difference though as far as i know.
In case you want to try again, have a look in the folder "src\platform" of your local source directory, there you'll find a diff file called "sdl-win32.diff" which, when applied to the SDL source code, enables Direct Draw output. But it only applies version 1.2.12 of SDL, for the current version 1.2.15 you'd have to make some changes first, so it's easier just to use a already compield one, as Qbix said.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 14 of 14, by Anonymous MOS
Thanks for the input, guys!
My .exe has all of the libraries compiled inside of it. Wouldn't mind having the latest version of SDL, but I'm using 1.2.14 because of compatibility worries.
With mine having everything all in one I think I'd have to fix it, or re-compile with different settings so I could have separate .dll files.
Could anyone point me to a guide or something?
I'd like to end up being independent enough to be able to compile all future SVNs, and upgrade all the libraries as needed.
Alienware Aurora R7
16 Gigs RAM
