First post, by Serious Callers Only
I'm doing a small patch to dosbox to use these from package install.
What i want is to be able to use the files by just specifying their filename (note: not path), like the built in shaders.
So i want to add another fallback after the 'currentdir/shader.glsl' and 'configdir/glshaders/shader.glsl'. Trouble is i don't understand the code very well.
This is the code:
	char* shader_src = render.shader_src;
Prop_path *sh = section->Get_path("glshader");
f = (std::string)sh->GetValue();
if (f.empty() || f=="none") {
free(render.shader_src);
render.shader_src = NULL;
} else if (!RENDER_GetShader(sh->realpath)) {
std::string path;
Cross::GetPlatformConfigDir(path);
path = path + "glshaders" + CROSS_FILESPLIT + f;
if (!RENDER_GetShader(path) && (sh->realpath==f || !RENDER_GetShader(f))) {
sh->SetValue("none");
LOG_MSG("Shader file \"%s\" not found", f.c_str());
RENDER_GetShader gets the shader definition and returns true if it succeed. I was thinking of changing this code to add another dir fallback - remember this code only runs on the package install, so linux only, so i don't need to care about portable paths
My trouble is not understanding what's the difference between the 'f' from 'sh->getValue' and 'sh->realpath'. It appears that the fail condition is super complicated for no reason if those two are always equal like i suspect, and i could do :
		std::string path;
std::string path2;
path2 = "/usr/share/dosbox/glshaders/"+f
if (! (RENDER_GetShader(path) || RENDER_GetShader(path2)) ) {
Can sh->getValue here really be different from sh->realpath ? If so what's the difference, getValue is the filename and realpath the whole path?
[edit by Dominus: split this off some more shaders for SVN r4319 and later]
Reply 2 of 9, by Serious Callers Only
Dominus wrote on 2020-04-15, 11:35:
If it's in the right folder you can already use them by name only.
You're missing the point maybe, i can't place glsl files on a user dir during a package install because it's not allowed, and if it was it would be broken as soon as the user deleted the dosbox conf home. Package files need to go into read only package dirs, to be updated when the package updates (which it does automatically with launchpad ppas). So in order to use the 'small name' i need to have a extra fallback to that system dir.
Reply 4 of 9, by jmarsh
Serious Callers Only wrote on 2020-04-15, 11:30:
Paths in the config file may be relative to the location of that file, realpath handles that translation.
Reply 5 of 9, by Serious Callers Only
Still confused jmarsh :
else if (!RENDER_GetShader(sh->realpath)) //tries to turn path relative to current conf file and check if it exists,
if ( !RENDER_GetShader(path) //if that fails tries to read from config path+raw 'glsl path' string
&& (sh->realpath==f || !RENDER_GetShader(f))) //if that fails, and if the raw path is different from the 'relative to conf' path, try to read from the raw path
Shouldn't the order be
1. check path relative to current conf file
2. check raw path
3. only fallback to confhome+raw after both of these fail?
Like this:
 else if (!RENDER_GetShader(sh->realpath) && (sh->realpath==f || !RENDER_GetShader(f)) ) {
std::string path;
if ( !RENDER_GetShader(path)) {
which i'd turn into
std::string path;
std::string path2;
path2= "/usr/share/dosbox/glsl/"+f;
if ( !RENDER_GetShader(path) && !RENDER_GetShader(path2)) {
edit: mmh, maybe i should just remove the sh->realpath==f check and reorder. It looks like a optimization.
Last edited by Serious Callers Only on 2020-04-15, 12:55. Edited 3 times in total.
Reply 6 of 9, by jmarsh
Serious Callers Only wrote on 2020-04-15, 12:47:
No. The ability to override the built-in shaders was intentional in case it was discovered they didn't work with certain hardware.
Reply 7 of 9, by Serious Callers Only
that makes sense.
std::string path;
std::string path2;
path2 = "/usr/share/dosbox/glshaders/"+f;
if ( !RENDER_GetShader(path) && !RENDER_GetShader(path2) && !RENDER_GetShader(f) ) {
read relative to conf, read from dosbox dir to override, read from the 'fixed' shader path, read raw file. The sh->realpath==f looks like a optimization and it makes my feeble brain not understand the condition, so if it goes away i'm almost sure it's correct. Files in path2 won't be the same as the builtin shaders, and files in the dosbox main dir will override always if not relative to the conf file, so it's ok. I think.
Reply 8 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
split this from some more shaders for SVN r4319 and later
if you need a more appropriate subject, let me know 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 9, by Serious Callers Only
This is already done and running, no need for more posts.
