CVS Builds By AEP
Reply 20 of 51, by HunterZ
XTale: Sounds like maybe you're using different dosbox.conf options than some people? Might try running with no dosbox.conf to see what the default options do.
Reply 21 of 51, by XTale
i'm doing the same as you - take the zip, decompress it and start dosbox.exe - no conf at all
http://www.aep-emu.de - AEP Emulation Page
http://cvscompile.aep-emu.de - DosBox CVS builds
Reply 22 of 51, by rcblanke
Hi guys,
I noticed that the alt-tabbing issue is related to sdl.dll, at least, for me. When I replaced the dll from may 7th with the dll from oktober 2004 (the one that goes with 0.63), the problems went away.
Can anybody confirm this?!
Regards,
Ronald
Reply 23 of 51, by Qbix
Rank DOSBox Author
DOSBox Author
yes it seems the problem was with sdl.dll.
which source did you use for sdl.dll Xtale ?
I checked their cvs and not that much has changed.
Water flows down the stream
Reply 24 of 51, by XTale
was the official 1.2.8 zip.. weird... seems to went something wrong on compiling, I'll rust replace the dll in the zip
Reply 25 of 51, by XTale
Someone got dosbox working GOOD with a SDL1.2.8 dll?
If I build a sdl.dll version 1.2.8 there are some possibilities:
- I build without directx support -> I get the dll where alt+tab doesnt work (the one i bundled with my builds last time)
- I build with directx support -> I get a dll, where I can't enter fullscreen on my laptop (no output found - or something similar - as error message), no difference if I do the changes to sdl-souce mentioned by hunterz or not.
- I build agains 1.2.8 headers and put the official compiled sdl.dll from libsdl.org in the directory -> I get an error on starting and no working dosbox at all
Either sdl is a bit buggy or my laptop doesn't like sdl
Reply 26 of 51, by HunterZ
Try the one I posted in the Munt+DOSBox thread.
Reply 27 of 51, by SaxxonPike
Any way to lower the sound buffer? It's like, a whopping second delay. Speaking of which, what other config stuffs can we do?
Reply 28 of 51, by HunterZ
Open your DOSBox.conf and find out. There are lots of descriptive comments in there that tell you what the settings are for.
Reply 29 of 51, by SOFTCell
Hello,
first of all, i'm a new user of DOSBox - but I'm deeply impressed how good it works !!! 😎
Ok. I have some things I observed with the latest version of this build:
1) Crucial for me - i need serial support. Is it not implemented? I found an (older? other?) cvs here in this forum that worked ... and W311 in MSDOS runs with that version. Anyway ...
2) Try to boot a MSDOS 6.22. Open the DOS-Editor. Close it - background color changed. No big deal unless you have black letters on black background 😖 .Starting the Editor 'blind' again and close it (also blind) and the background color is changing again. Some kind of color-cycling???? In the log window there are also some messages concerning 'XGA unsupportes multiread ...'. Unfortunately I'm on another PC at the moment and can't tell exactly the message ...
Keep up the good work !!!
Reply 30 of 51, by SOFTCell
.... sorry, wanted to write white letters on white background ...
Reply 31 of 51, by XTale
I just posted a new build - with a freshly setup mingw/msys
If the problems with sdl are still there, it's my laptops fault 😉
Reply 32 of 51, by kruwi
Why hasn't the the page providing the "not patched up" cvs-builds (cvs builds by AEP) not been updated since march? That was well before the 0.65 release.
Reply 33 of 51, by wd
Rank DOSBox Author
DOSBox Author
Because you didn't pay enough.
Reply 34 of 51, by kruwi
Can you please explain this to me again?
Reply 35 of 51, by Eck
He's (She's?) mess'n with ya.
There probably haven't been dramatic changes since the release build 0.65 so there's no point to posting it yet. Those that need the special features of the unofficial builds have those available. Don't use the AEP build on 0.65, as it's made for 0.63.
Reply 36 of 51, by Qbix
Rank DOSBox Author
DOSBox Author
those builds are created for free. So don't expect anything and be happy with the ones you got.
Reply 37 of 51, by XTale
Well.. there's a world beyond the internet, and that one is taking a lot of my time at the moment.
Nevertheless I put a new build online (no screenshots support as libpng is bitching around)
Reply 38 of 51, by Tabris:DarkPeace
Forgive my ignorance, but what does AEP stand for or imply regarding the DosBox CVS(s) ?
[I've got over a decade of DOS experience, I think I predate "AEP"] 😜
http://users.on.net/~darkpeace
