First post, by nexxu
mkdir /tmp/x
cd /tmp/x
touch autoexec.bat
chmod +x autoexec.bat
dosbox . -c autoexec.bat
dosbox 0.65, happend on slackware 10.2
not sure if it is something wrong w/dosbox or only w/my slackware setup
% kill -9 -1
Reply 2 of 6, by DosFreak
What is the issue?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
We should care until we have an idea of WHY this happens. It could be a symphtom of something more serious. Once the cause is (roughly) known, then it is okay to ask "why should we care for that".
_________________
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
-c adds a command to autoexec.bat
so the last command of autoexec.bat is to execute autoexec.bat
(the creation of autoexec.bat isn't needed. DOSBox uses and calls the autoexec.bat from Z : \ )
if you want to run your own autoexec.bat after dosbox it's autoexec.bat:
dosbox ./autoexec.bat
Water flows down the stream
