Reply 20 of 35, by Chris_AU
Hi h-a-l-9000
Another quick update for you.
You've probably worked this out already, but it is every leap year that this date issue happens... all other years appear to work fine.
Is this something that you maybe able to correct on you next update 😀 , or is it something we simply need to live with 🙁 ?
Thanks for all the work you have done with DOSBox to date... it's great.
Cheers
Chris
