First post, by n1mr0d
In the past i used to collect computer viruses, and recently i found my virus archive disk. On it were 2 boot sector files of disks infected with the infamous Ping Pong virus, which i caught in the wild. If you boot from an infected disk, a lozenge appears that bounces off the walls of the screen.
One curiosity of the virus is that it only runs on 808x machines, because of the MOV CS,AX instruction, which is illegal on later processors (crashes). I tried to boot the sector (and a floppy image with the sector) with the BOOT command, but unfortunately dosbox crashed immediately.
I thought that correctly emulating this would prove that dosbox is coming close to the real thing. For those who want to dabble around with/analyse it, i attached the virus and (dis)assembly file.
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
dosbox aims at 386+ emulation, so this is out of scope. But should be no
problem to hack the mov cs,ax into the normal core if you can compile
dosbox from sources and have some use this.
Reply 2 of 6, by n1mr0d
Any clue how dosbox handles writes to the CS register?
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
prefix_none.h for the normal core, case 0x8e: MOV Sw,Ew
where the which (==seg reg ID) is 1.
See CPU_JMP (the stuff in the first if() block, which deals with
real mode far jumps) for how to change the cs segment,
ie. use SegSet16().
I've removed the archive btw.
Reply 4 of 6, by icemann
Why collect viruses out of curiosity?
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 5 of 6, by CarlKenner
Actually I don't think DOSBOX is just intended for 386s. Otherwise why would it have machine=cga. I use it for all my classic 808x games.
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
Um graphics are a tad what unrelated to processor emulation.
Of course most 8086-style games work fine on a 386+ processor
if the speed is low enough (cycles setting) and the graphics
emulation fits its needs (cga).
