First post, by engla
Hi
I'm trying to compile dosbox 0.73 directly from the website on my debian/powerpc system (using debian testing). The compilation requires lots of memory and goes on to compile some files, until stopping on one file, simply growing memory use without "ever" (1-2 hours waited) finishing. So I can't compile this at all. I have dosbox 0.72 installed via binary packages from debian.
Anyone seen this? I've tried with gcc v4.3 (default) and 4.2
Reply 2 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
which file specificly ?
core_prefetch ? That one brings down my machine almost to its knees as well
Water flows down the stream
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well at my place the Out of Memory killer kills almost everything and I have 2 GB of RAM when compiling.
I think it is somehow related to the GCC version though.
Reply 5 of 7, by engla
yes, of course it is the same file. I only have 768M RAM so I think it gets into paging and simply ..won't finish in my lifetime.
I found an option to *enable* memory inlining "--enable-core-inline" (must be disabled by default then huh?) so I'll try that.
Basically I want to get Dungeon Keeper to work on my linux/powerpc ibook, 0.73 is a last hope but I still think the emulation is too slow sadly. The proc is only 1.2 GHz. Works fine only on newer macbook/x86 that I have tried.
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
for core_prefetch remove the INLINE from FetchD/W/B calls and it doesn't use over 1Gb of memory when compiling.
