First post, by AMIGrAve
Hi all,
I've got two monitors running nvidia twinview under linux.
Dosbox was always going fullscreen on my first monitor and my goal was to use the second monitor. I was frustrated until I found out the SDL_VIDEO_FULLSCREEN_HEAD environement variable which allow me to use my second monitor :
SDL_VIDEO_FULLSCREEN_HEAD=1 dosbox
As I had a similar problem with sdlmame, I tried this
SDL_VIDEO_FULLSCREEN_HEAD=1 sdlmame
But it doesn't work. I'm currently asking help on the sdlmame forum :
http://www.bannister.org/forums/ubbthreads.ph … 50869#Post50869
According to R. Belmont, dosbox is probably the only application working with this sdl env variable.
So I'm aslking sdl devs here if they did something special in order to make dosbox work with SDL_VIDEO_FULLSCREEN_HEAD ?
Fabien Meghazi
http://www.amigrave.com
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
nope, you could try our SDL.dll with sdlmame though
Maybe it is a version difference
Water flows down the stream
Reply 3 of 5, by AMIGrAve
I didn't tough about trying a demo.
Indeed I took this demo :
http://www.libsdl.org/projects/aliens/
and I could use SDL_VIDEO_FULLSCREEN_HEAD successfully.
Going back to sdlmame forum with this info. Thanks !
Fabien Meghazi
