First post, by kr_217
Hello,
I want to implement network boot to various machines.So i setup the PXE server on one particular machine.As i want to deploy linux related images on various machine i have a "dd" image on the PXE server and through this i deploy the image by sending initrd to machine and this initrd contains dd command which execute the dd image.Until this every thing works fine.
My problem is there is ghost file(.gho file) which i need to flash on this machine.So i have a ghost11.exe which can execute these gho file. But this ghost11.exe cannot be run on linux because it is windows application.So i installed dosbox application in linux and in that i try to
run ghost11.exe.But ghost11.exe fail to recognized the partition of the machine.Is there any way dosbox list the partition for the local machine.
Waiting for the reply.
Thanks
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
nope. DOSBox is for games. don't do lowlevel things like writing partitions. Get a different tool
Water flows down the stream
Reply 3 of 7, by ppgrainbow
Norton Ghost (ghost11.exe) will neither run on DOSBox nor on the Linux host since the kernel has no native support for executable files. DOSBox is meant for games and vintage operating systems and not all OSes work.
If you want to use DOSBox with a virtual hard disk, you are welcome to create hard disk image up to 504 MB. You can expect some severe limitations that I dealt with when booting from a hard disk image under DOSBox.
Edit: As wd, put it, it would be wise to use a emulator such as Bochs or Qemu. DOSBox has severe limitations that will not overcome anytime soon.
Reply 5 of 7, by ppgrainbow
I recall that Bochs isn't 100% stable as you might think. I ran a couple guest operating systems (Windows 3.1, Windows 9x and Windows 2000) for testing purposes only to find that Bochs can freeze up and crash. I'll try to look up these issues on Google for help.
I would rather use Qemu 0.9.0 (as Qemu 0.9.1 and Qemu 0.10.x have stability and video corruption issues), VirtualBox, VMware Player or Virtual PC.
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
Bochs is the most stable of those, yet i didn't follow the later versions closely
and their speed improvements may have an impact on compatibility (this is
pure guessing judging the cvs commits to the cpu part).
Reply 7 of 7, by ppgrainbow
That's what I've been thinking. It's the CPU part. If you don't set the CPU instructions per second high enough (at least 50 million IPS), Bochs could lock up.
I also tried to get the sound card emulation to work under Bochs and the sound would eventually skip.
I can try to test out one of the operating systems to see how it goes such as Windows 3.1 running on top of Caldera OpenDOS 7.01 under Bochs.
The latest version of Bochs is version 2.4.1.
