First post, by ustcmarkness
Hi,
As I converted the visual/dosbox.dsw(VC 6.0) of DosBox 6.5 to the visual studio 2002(VC 7.0), some problems came.
dosbox fatal error C1083: Cannot open source file: '\Work\dosbox\dosbox-0.65\src\cpu\slow_16.cpp': No such file or directory
dosbox fatal error C1083: Cannot open source file: '\Work\dosbox\dosbox-0.65\src\hardware\serialport.cpp': No such file or directory
dosbox fatal error C1083: Cannot open source file: '\Work\dosbox\dosbox-0.65\src\hardware\softmodem.cpp': No such file or directory
dosbox fatal error C1083: Cannot open source file: '\Work\dosbox\dosbox-0.65\src\ints\dpmi.cpp': No such file or directory
I wonder how to use the Microsoft's Visual C++ 2002 to successfully build DOSBox.
Thanks.
My friends!
Reply 2 of 4, by HunterZ
The DOSBox Wiki has instructions on building DOSBox in Visual Studio Express 2008 I think. You might try following the Wiki instructions and either using VSE or at least try using the DOSBox 0.73 sources.
Reply 3 of 4, by ustcmarkness
Thanks for all!
Oh, the version of bosbox is 6.3. I'm trying to compile it using Visual C++ 7.0 undet Mircrosoft Development Environment 2002 Version 7.0.
Now, the problem is solved. It can be compiled successfully.
But when I ran the project, the keyboard couldn't work!......
My friends!
