Debian Build
First post, by nudgegoonies
I can't wait any longer. I did everything, from googleing for hourse till trying out various ubuntu builds on my stable Lenny but i found no 0.73 working!
I did nearly everything but compiling, this is what i can't and what i won't do!
I don't want to wait until Squeeze! I want to configure my Games for 0.73 now!
Has anyone a DEB wich runs on plain lenny without depends on squeeze?
Thanks in advance!
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
my debian system that I use is currently not available, but the compiling process is pretty simple
Water flows down the stream
Reply 2 of 8, by nudgegoonies
Simple? The compiling itself was simple. After the work with installing the whole *-dev stuff. After looking working with the dosbox_0.72-1.1.diff.gz to extract the debian directory with the build rules. After changing changelog, DEBIAN.readme and dosbox.conf.example. After applying the patch in the bios_keyboard.cpp. After searching for the command for the build process...
    dosbox_0.73-1_i386.zip
    787.6 KiB
    412 downloads
    Build by me for plain Debian Lenny. Rename from .zip to .deb before installing with dpkg -i.
Reply 4 of 8, by nudgegoonies
I wanted to create a deb to keep my system clear. The only modification is the patch to bios_keyboard.cpp wich seems to be needed. It is an easy patch. Simply removing two slashes before a define. The stuff in the debian directory seems to be needed for the deb build process. There were a lot of patches in the diff for 0.72 wich i havn't applied because i think they were bugfixes from the cvs versions or they were patches by the maintainers.
    dosbox.tar.gz
    19.58 KiB
    376 downloads
    These files need to be in the dosbox-0.73 source directory. To start the build process enter: dpkg-buildpackage -rfakeroot -us -b
Reply 5 of 8, by nudgegoonies
To be true, the compiling by self process is to complicated for beginners. But beginners wouldn't really use Linux on the desktop 😉 But i think binaries for the most popular linux distributions, those who don't have the actual dosbox in their reposities or in their backports, would be useful for a lot of people.
Regards,
Andreas
Reply 7 of 8, by AndrewWhite
Regards,
Andreas
I have made a deb for you of the latest version. It has all of the requirements that dosbox has I do not think I put the required packages into the deb so you will need to install them yourself if you are missing them.
    Dosbox_0.73-1_i386.tar.gz
    768.04 KiB
    403 downloads
Reply 8 of 8, by kruwi
why don't you want to compile the sources?
Installiung the dependencies (the required dev-packages) is pretty easy. And if you don't want to mess with your system, well:
You don't actually have to do a "make install"! "Configure" and "make" will suffice, after that you can just run the executable from your home directory like this: "./dosbox". No messing around with your system, all of root's directories will stay tidy.
Visit the end of the internet: www.groskreutz.de
