First post, by haimkob
Hello,
I've tried to compile the dosbox source with MiniGW using this instructions:
http://www.dosbox.com/wiki/BuildingDOSBox
As a result i get the dosbox.exe compiled file in size of 19MB (2.1MB after compress),
while the dosbox.exe which included of the official release is only 3.6MB (1MB after compress).
I would like to know why there is the big differ on file size?
and how can i make my compiled file the same size as the file included on official release.
Thank you.
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
sure why not. you don't use the same libs, compiler, compiler flags as used with the release
Water flows down the stream
