First post, by Malvineous
Hi all,
I've just added support to AdPlug for the new .dro format, however the DOSBox code looks like it's endian specific, which means I will need to add extra code to correctly play files captured on the opposite architecture to playback.
To confirm this I'd need a capture from a big-endian machine, but the only machines I have access to that can run DOSBox are little-endian (Intel.) If anyone out there has a big-endian machine (non-Intel Mac?) and they could send me a .dro capture with the latest version of DOSBox, that'd be great!
Reply 1 of 12, by koun
We have an iMac G4 at work that might still work. (It is currently used as a picture frame, and I don't mean digital picture frame.)
If this system fits your needs, please describe what you need done (or link to a post/article/... describing it) and I'll see what i can do.
Reply 2 of 12, by Malvineous
Thanks for the offer, sorry about the delay. All I need is an OPL capture - run DOSBox, start a capture (Alt+Ctrl+F7 by default) and run something with Adlib music (try this bbstro if you don't have anything handy.)
Leave it running for about 15 seconds (that's all I need) then press Alt+Ctrl+F7 to stop the recording and you should have a .dro file created. If you can post that here it'd be very helpful!
Reply 4 of 12, by Malvineous
Possibly. Often for efficiency reasons the bytes will be swapped on big vs little endian architectures (see Wikipedia for details) so whether this is a bug or not is open for discussion.
Of course it only *looks* like it will happen, I'd need to see a big endian capture first to be positive.
Reply 5 of 12, by robertmo
I think that if a big endian capture happens to be positive the thing to do first would be to try to make dosbox code not endian specific, and patching your player only if it couldn't be solved that way.
Reply 6 of 12, by Malvineous
I guess that's up to the DOSBox devs to decide. The code could certainly be fixed, but whether anyone is willing to do so...
Reply 7 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
if it gets captured wrong on big endian than is a bug. Would be easy to fix probably.
Water flows down the stream
Reply 9 of 12, by koun
Here is the file. It is renamed, not zipped.
(edit: forgot the file)
    digi.zip
    5.1 KiB
    264 downloads
    dro capture on non-Intel Mac
Reply 11 of 12, by Malvineous
Ah excellent, many thanks for that koun! It looks fine and plays without any trouble, so that answers my question. No bug in DOSBox 😀
