First post, by ih8registrations
/* more 16:9 modes */
{ 0x226 ,M_LIN8 ,400 ,224 ,50 ,28 ,8 ,8 ,1 ,0xA0000 ,0x10000,120 ,500 ,100 ,448 , _VGA_PIXEL_DOUBLE | _EGA_LINE_DOUBLE },
{ 0x227 ,M_LIN8 ,512 ,288 ,64 ,36 ,8 ,8 ,1 ,0xA0000 ,0x10000,148 ,625 ,128 ,576 , _VGA_PIXEL_DOUBLE | _EGA_LINE_DOUBLE },
{ 0x228 ,M_LIN8 ,640 ,360 ,80 ,45 ,8 ,8 ,1 ,0xA0000 ,0x10000,212 ,758 ,160 ,720 , _VGA_PIXEL_DOUBLE | _EGA_LINE_DOUBLE },
{ 0x229 ,M_LIN8 ,800 ,448 ,100,28 ,8 ,16 ,1 ,0xA0000 ,0x10000,120 ,500 ,100 ,448 , 0 },
{ 0x22a ,M_LIN8 ,1024,576 ,128,36 ,8 ,16 ,1 ,0xA0000 ,0x10000,148 ,625 ,128 ,576 , 0 }, // flickers. ? appears to be a quake issue, mode displays fine with a vesa test util.
{ 0x22b ,M_LIN8 ,1280,720 ,160,45 ,8 ,16 ,1 ,0xA0000 ,0x10000,212 ,758 ,160 ,720 , 0 }, // 720p
Quake makes use of them.
Reply 1 of 5, by ih8registrations
Can use these widescreen modes in duke3d with the attached utility.
duke3d has no problem with flickering in 1024x576 like quake.
    cfg.zip
    6.06 KiB
    265 downloads
Reply 2 of 5, by DosFreak
Wouldn't it be easier to just edit duke's cfg file? or does this utility modify the executable?
Make your games work offline
Reply 5 of 5, by DosFreak
ih8registrations wrote:
I find using the utility is faster/easier than opening the config with an editor, move to resolution lines, edit, save, exit, but if that's what you prefer doing..
Just being paranoid. 😉
