First post, by Sicki87
Hey 😀
All games are working fine in the normal window mode. but if i change in fullscreen alle colors are wrong
for example red turn into yellow ..... this looks horrible. and this problem exist in each game !
i tried to change in dosbox.conf.txt the output graficmode from surface to overlay, opengl, openglnb and ddraw. but this doesnt help 🙁
My PC is Windows 7 home premium 64bit, Intel i5 750, Radeon 5850, 4gb ram
Reply 2 of 3, by ripa
"i tried to change in dosbox.conf.txt the output graficmode from surface to overlay, opengl, openglnb and ddraw. but this doesnt help"
If the configuration file is called dosbox.conf.txt then dosbox probably isn't using it. Look at dosbox's status window to see which config file it loads. Put "echo lol noob" (without the quotes) at the end of your config file (under the autoexec section) and Dosbox will print "lol noob" when it starts and you'll know the correct config file is loaded.
