First post, by miriam11
DOSBox-0.72-Debug(exe from rapidshare) and DOSBox-0.74 (build from this sources).
Configure on mingw using:
./configure --enable-debug=heavy
After I go to debugger and trace instruction (F11) it jump more instruction that one. Also commend LOG 10 ignore some instructions and double log some. Is this a normal behavior?
Reply 1 of 1, by aqrit
set core=normal
