Yet another win32 DOSBox SVN compiling thread
First post, by marooned_on_mars
I tried recently compiling DOSBox by myself but am unable to as my attempt ends up in MinGW complaining for missing SDL. The DOSBox wiki article isn't very explicit for beginners (like me) so I'm not sure what am I supposed to do. I opted not to complicate myself and skip compiling SDL myself too. Here's what MinGW reports:
$ ./configure
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make sets $(MAKE)... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for ranlib... ranlib
checking for sdl-config... no
checking for SDL - version >= 1.2.0... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
configure: error: *** SDL version 1.2.0 not found!
Any suggestions?
Also, how could I add patches to DOSBox? That's also missing from the wiki and INSTALL.
Keep in mind that I never (successfully) compiled anything so sorry for my illiteracy. ^^
Thank you in advance~
Reply 4 of 70, by VileR
I'm pretty sure it's necessary to compile SDL (and SDL_net if you need that too). The wiki article needs an update anyway...
Let's say you extracted "SDL-1.2.15.tar.gz" and "SDL_net-1.2.8.tar.gz" into their own directories under your user folder in mingw:
- Navigate to ~/SDL-1.2.15 and compile SDL:
./configure
make
make install
- Navigate to ~/SDL_net-1.2.8 and compile SDL_net:
./configure
make
make install
- Add the libraries to your PATH variable:
PATH=$PATH:~/SDL-1.2.15
PATH=$PATH:~/SDL_net-1.2.8
Reply 5 of 70, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You don't need to compile SDL you just need to place the mingw package correctly. Wiki article is writing something wrong in regard to this.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 70, by marooned_on_mars
I've tried following this guide in that regard, but it still complains it cannot find SDL.
How would I "place" the SDL package? (again, sorry for my illiteracy)
Reply 8 of 70, by marooned_on_mars
gulikoza wrote:
You should uncompress SDL-devel into your home directory inside msys, run msys and type 'make native' to install it.
That fixed the problem, thanks. Now I tried to add the MUNT patch to DosBox (with the help of the guide provided by bloodbat), and it complains about missing files...
midi.cpp:106:23: fatal error: midi_mt32.h: No such file or directory
compilation terminated.
make[3]: *** [midi.o] Error 1
make[3]: Leaving directory `/d/Downloads/dosbox/src/gui'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/d/Downloads/dosbox/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/d/Downloads/dosbox'
make: *** [all] Error 2
I have no idea where to get that file since it didn't come with the .diff file.
Reply 11 of 70, by Dominus
DOSBox Moderator
Again you first need to compile munt. With cmake in msys/mingw
Reply 12 of 70, by marooned_on_mars
Compiling with cmake gives me this:
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:2 (project)
CMake Error: your CXX compiler: "bcc32" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
Configuring incomplete, errors occurred!
Reply 14 of 70, by Dominus
DOSBox Moderator
and when you have this sorted out, make sure you only cmake the lib and nothing else, because the other stuff wants glib2 (and that brings a whole other hell to compiling life 😀)
Reply 15 of 70, by marooned_on_mars
bloodbat wrote:
You need to configure cmake to point to your correct compiler (GCC) it defaults to Borland...
Read here:
http://www.cmake.org/Wiki/CMake_FAQ#How_do_I_ … ent_compiler.3F
Would that correct compiler be under Mingw? I'm not sure where I'm supposed to find it. Also have no idea what that generator would stand for ^^;
Reply 16 of 70, by bloodbat
If using their automated installer with default paths or following one of their guides it lives in c:\mingw\bin\g++.exe (why you are trying to compile something without knowing at least where your compiler is...is beyond me).
As for the generator you probably want CMakeLists.txt and to read this http://www.cmake.org/cmake/help/cmake_tutorial.html
Reply 18 of 70, by marooned_on_mars
Sorry for the double post, copied the MUNT files in dosbox/src/gui/ (where it was looking for "midi_mt32.h" ) and it seemed to work, up to this point:
make[3]: Entering directory `/d/Downloads/dosbox/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I../include -I/usr/include/SDL -D_GNU_SOURCE=1 -D
main=SDL_main -g -O2 -MT dosbox.o -MD -MP -MF .deps/dosbox.Tpo -c -o dosbox.o
dosbox.cpp
mv -f .deps/dosbox.Tpo .deps/dosbox.Po
windres -o winres.o winres.rc
g++ -g -O2 -o dosbox.exe dosbox.o winres.o cpu/libcpu.a debug/libdebug.a dos
/libdos.a fpu/libfpu.a hardware/libhardware.a gui/libgui.a ints/libints.a misc/
libmisc.a shell/libshell.a hardware/serialport/libserial.a libs/gui_tk/libgui_tk
.a -L/usr/lib -lmingw32 -lSDLmain -lSDL -mwindows -lopengl32 -lwinmm -lmt32emu
c:/mingw/bin/../lib/gcc/mingw32/4.7.2/../../../../mingw32/bin/ld.exe: cannot fin
d -lmt32emu
collect2.exe: error: ld returned 1 exit status
make[3]: *** [dosbox.exe] Error 1
make[3]: Leaving directory `/d/Downloads/dosbox/src'
Reply 19 of 70, by Dominus
DOSBox Moderator
You need to cmake the mt32emu lib and place it in the lib folder...
