First post, by LordKaT
Heyah,
I've been screwing around with The ImagiNation Network latley, and I was curious as to how well the emulated modem worked in the latest CVS. Well, that, and I've always wanted to screw around with INN, and this appeared to be the most assbackwards way possible 😀
Anyway, I setup a small TCP/IP server to receive data. I noticed that all I could receive was an "@" (TX add @). Is this sent from the program (INN) or is this sent by DOSBox to open a modem connection?If this is sent by DOSBox, what is the appropriate response?
Thanks for your time,
Jason
