dosbox edit command
First post, by sageek
Hi. i am sagi kerman and i am a computer programmer in over 20 languages. i am using dosbox for a month an a hath now. it is getting very annoying that i have to go to the mounted folder on the computer and change the files from there. i'd love if you will add some veirson of the edit command soon. thank you, sagi kerman.
[code]a 100
jmp 115
db 'Hello, World!$'
a 115
mov ah, 09
mov dx, 102
int 21
int 20
h 11e 100
rcx
1e
n hello.com
w
q[/code]
Reply 1 of 4, by gamax92
Or, you could just use MS-DOS's EDIT.COM or the several hundred editors that exist for DOS
Like this: http://www.freedos.org/software/?prog=edit
or these: http://www.bttr-software.de/freesoft/txtedit1.htm
or these: http://www.bttr-software.de/freesoft/txtedit2.htm
or even these: http://texteditors.org/cgi-bin/wiki.pl?MsDosEditors
Reply 2 of 4, by 2fort5r
Is it possible to paste clipboard text into DOSbox? I was trying to do this yesterday but couldn't figure out how.
Account retired. Now posting as Errius.
Reply 4 of 4, by mr_bigmouth_502
Given DosBox's gaming-oriented nature, I doubt an editor will become a standard part of it anytime soon, but edit.com from an old DOS install or startup disc will probably work just fine.
