First post, by Barabbas
Hi!
First of all I have to thank for this GREAT Program. I tested more than 300 games and less than 20 did NOT work. *THUMBS UP*
Thanks for your work!!!
I found some micro- bugs (:D), just wanted to mention it:
1) Using relative Pathes (such as ".") in connection with dosbox function (i.e. mount) will make dosbox interprete those pathes in relation to the dosbox- installdir. This ist not really a bug, but in my opinion it would be more usefull, if dosbox would "read" those relative pathes from the base- dir of the virtual drive... if "c:\some_dirs\data" was mounted as "c:\" dosbox should understand "." as "c:\some_dirs\data", for example. (only in connection with DOSBOX- functions)
2) Using relative pathes with dos- functions - such as "subst" - is understood as relative path in relation to the base- dir of the virtual drive. For that typing "subst a: ." will in most cases lead to a "Directory X doesn't exist" because subst asks for a directory on the VIRTUAL drive. I think virtual drive an real- basedir were mixed up here.
3) Using relative pathes for pathes containing spaces will lead to an error; example: "subst a: ." will not be found if "." stands for "c:/documents and settings/etc".
Ok, i hope my explanations were understandable,
cu
Barabbas
