Reply 40 of 43, by DosFreak
- l33t++
or just use winimage to load the HD image and copy anything you want to it.
or just mount folder together with image....
Hint: I've tested a smaller image from VMWare Workstation. 0,1GB. Booting doesn't work with this image. No idea why. Perhaps IsoBuster does something wrong with the image after installing dos in VMWare Station.
But 1 Gig Image does its work just fine. 😉
Little more question: How can i mount an image AND a folder together in one partition? (DFend)
Hello everybody,
I'm sorry for pushing up this old discussion...
Is there a way to play "Pizza Connection" with sound but without booting a real DOS?
Apparently it is not enough just to replace the sound.com file from "Pizza Connection" with the one from "Pizza Tycoon"...
I'm using D-FendReloaded and I tried adding these lines to the autoexec.bat file (Profile editor > Starting) but I have still no sound... 😕
DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5 /WIN95
DEVICE=c:\SB16\drv\ctmmSYS.sys
SET BLASTER=A220 I5 D1
Are the sound settings you can see on the attached screenshot correct?
Thanks in advance for your help!
