dosbox-macbuild - script for building 64-bit SVN on macOS
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby emendelson » 2018-4-13 @ 15:01
Apologies if everyone knows about this, but there's a script by "gs11" on GitHub for building a 64-bit version of SVN - completely automated and very impressive:
https://github.com/gs11/dosbox-macbuild
As far as I can tell, the one thing it can't do is build a static-linked executable that can be used on systems without sdl installed. I've filed an issue about that, and I hope there's some chance it can be done. Dominus worked out a method for building static-linked SVN in macOS, but I haven't been able to make his method work with this script.
emendelson
Re: dosbox-macbuild - script for building 64-bit SVN on macOS
Postby emendelson » 2018-4-14 @ 02:51
Well, it turns out that gs11's script does produce a static-linked executable if SDL 1.2 is NOT installed in /usr/lib. When I got rid of SDL 1.2 in /usr/lib, all went well.
emendelson
Postby Dominus » 2018-4-15 @ 09:34
you really shouldn't have anything in /usr/lib that Apple didn't put there. That is asking for trouble with every package manager and things like this script.
As for the script, be aware that this is a bare bone Dosbox. No SDL_net, no SDL_Sound, no libpng. So networked gaming won't work, image mounting is crippled and no screenshot support.
User avatar
Dominus
DOSBox Moderator
Postby emendelson » 2018-4-15 @ 16:55
Dominus wrote:you really shouldn't have anything in /usr/lib that Apple didn't put there. That is asking for trouble with every package manager and things like this script.
Yes, and since I don't even remember how I got that stuff into /usr/lib, it's really time to get rid of it.
And yes, it's a barebones DOSBox. But it may be possible to add SDL_net and SDL_sound, etc. using the same method that it already adds SDL. I'll try this next week and will report back.
emendelson
Postby Dominus » 2018-4-15 @ 16:58
Yes, should be easy to add all that (just remember for SDL_Sound for DOSBox you also need ogg/vorbis - bit none of the other dependencies of SDL_Sound).
User avatar
Dominus
DOSBox Moderator
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 2 guests
