First post, by anonyme-x22
Hi,
Issue description:
Dosbox 0.72 capture dro 1.0 files whose don't works very good on some games and crash winamp adlib plugins but the instruments are quiet good recorded when opening them in opl3-bank-editor.
Dosbox 0.74 capture dro 2.0 files whose works better and don't crash winamp adlib plugins but the instruments are very bad recorded when opening them in opl3-bank-editor, there are about as many instruments as instruments changes in the song, and some are even not used/don't sound good.
So i must use dro 2.0 for capturing for further playback and archive.
But, i need dro 1.0 version for instruments bank making, and dro2midi conversion because i have to write the instuments list in the dro2midi inst.txt with the number of instruments in opl3-bank-editor. As dro 2.0 produce somethings strange with a lot of instruments it's not possible to use it.
Question:
Is it a bug of the dosbox 0.74 and dro 2.0 capture ?
Thanks in advance,
Have a good day,
Rgds,
