First post, by 1gnorance
so anyway, i have the Kings quest 6 CD. It doesn't say whether or not if its for Windows or DOS but im pretty sure its intended for DOS. so anyway, i ran the setup on the CD without using dosbox and it was able to install it... i think. i might try running the install through dosbox if i cant find a solution.
OK... so i mounted dosbox to the folder which is KQ6. Im doing this right. In the folder there is only one .exe file ... the rest are .src and im not sure if those can be run or not.... anyways, when i try to run the SCIWV.exe file... it says "this program requires Microsoft Windows" so im not sure if its the file i need to click to run the game, or if theres something wrong??
this is really frustrating so if you guys could help i would be grateful.
