abyss wrote:I do not want to get a windows port.
Jorpho was offering good advice, no need to throw a tantrum.
Running Quake with a frameskip of 10... you do realise that this isn't a good thing don't you? And 25000 cycles on a 500Mhz machine 'sounds' too high but hey whatever you think's best 😉
Should I suggest there are quite a few Quake ports available 😉 😁
DOSBox is very [very] good but with your machine you're not exactly getting the best from it. Windows ports will typically have better performance (those that are straight ports, not enhancements for example), VDMSound is also an option and finally an upgrade or three wouldn't go amiss!
