First post, by Wally
having some problems with The Lion King. The growl bar does not refill itself, sometimes it will when you die.
This is on Mac OS X build of dosbox.
Thanks
Wally
Thanks
Wally
Try a fixed and LOW number of cycles(the lowest that will give playable speed), if that doesn't work, try obtaining a newer version(don't remember how you can tell the version number though...). And please report back, I'm also trying to find a solution to this problem but unfortunately since the problem is not always reproducible, and since I don't really want to play this game, I don't want to test it myself.
