First post, by Turaga Nuju
Pre-amble:
I am aware that many people think this game is rubbish, but I happen to enjoy it.
Amble:
Exaclty this. How does one make Creature Shock work with DosBox or otherwise?
I have tried it on Windows 98 and Vista, and under DosBox. On DosBox and 98 I get to the first level but then it crashes.
Any Ideas?
Thanks,
Turaga Nuju
http://r3dmm.com
Reply 1 of 15, by wd
Rank DOSBox Author
DOSBox Author
[removed some "discussion"]
Tried loadfix?
Reply 2 of 15, by F2bnp
Hmmm what about trying to play it on pure DOS in the Win98?
Reply 3 of 15, by Turaga Nuju
I tried pure DOS, but it doesnt like the DOS4GW file.
I then tried a new version of DOS4GW (From this forum) but that did not work either.
What is this 'loadfix' ?
http://r3dmm.com
Reply 4 of 15, by wildweasel
Run "loadfix" in DOSBox, and it'll use up about 64 K of RAM for games that don't expect you to have so much free memory. Fixes some games, but your mileage may vary in this case.
Reply 5 of 15, by doomer
Creature Shock rules. 😁 I remember what it was to play it in 1994 and 1995. It is still great today. 😀
So here is what you need to make it run. It does not need loadfix. Set the memory to 16Mb. Install the game. Make sure you set the core to dynamic, and also set the cycles to not more than 40000. Otherwise Creature Shock outputs a dos4gw error. Crshock just doesn't run on faster machines.
Used to crash in the same way on my dos dedicated pc (350 Mhz PII), unless I ran moslow.
So set the cycles to 40000, and not more; core to dynamic, use dosbox 0.72. Plays fine with these settings. Enjoy 😀
Reply 6 of 15, by Turaga Nuju
Can you explain how to do that?
I tried a few things to no avail
http://r3dmm.com
Reply 7 of 15, by Turaga Nuju
Never mind, I figured it out. Thanks!
http://r3dmm.com
Reply 8 of 15, by ADDiCT
I've not tested the game yet (have it around somewhere), but using DOS/32A instead of the original DOS4GW could make it run better. I'm using DOS/32A with all DOS4GW games, with very good results. Most games run more fluid and a bit faster with DOS/32A. Unfortunately, GLIDE accelerated games (Tomb Raider 3DFX, for example) will crash with DOS/32A, which is a known bug AFAIK.
Reply 9 of 15, by doomer
Glad I could help you. 😀 Enjoy the game
Reply 10 of 15, by Turaga Nuju
New problem, it doesnt save my progress.
Is there a way to get the save working, or will I have to do it all in one sitting?
http://r3dmm.com
Reply 11 of 15, by MiniMax
Rank Moderator
Moderator
Did you install the game from DOSBox or from Vista?
_________________
Reply 12 of 15, by Turaga Nuju
DOSbox
http://r3dmm.com
Reply 13 of 15, by Xelasarg
Maybe check your game files for copy protection?
"What's a paladin?!"
Reply 14 of 15, by doomer
It should save properly.. Saves okay here.. You need to make sure that the directory you have mounted is not write-protected on your actual hard drive.
Reply 15 of 15, by Turaga Nuju
Regardless, I decided to complete the first level, die and then see if it loaded. Slight hitch in that plan. I sat through all five levels in a row and finished the game 😁
http://r3dmm.com
