First post, by Antennaguy
I have an old DOS application that can only run on a Windows 3.11 system or older. It requires the user to move a hidden "key" from A: to C: before the software will run from the hard drive. To run it on a different computer, you must move the key from C: to A:, then move it back to C: on the other computer. The move command won't work on Win2000 or XP machines.
Can I use DOSBox (or another application) to run this application on a newer, faster computer?
