First post, by legolas77
HELP ME, PLEASE !!!!
I have bought this great game on Gog and I have Installed last Dos Box 0,74-3, I use Gog Galaxy, I have finished the game SEVERAL TIMES. At the end of the game you can choose T17 character. But after several matches the game crashes on desktop....HELP ME !!!! CORRECT THIS BUG, I WANT TO FINISH THE GAME WITH T17, THANK YOU !!!!!
Reply 1 of 7, by MrFlibble
GOG builds are notorious for not being exactly optimized. For starters, why don't you try a newer SVN build of DOSBox instead of 0.74-3? Like the one here?
Also, when DOSBox crashes, it should leave a stderr.txt file in its folder. Can you reproduce the crash, then grab this file and upload it here?
DOS Games Archive | Free open source games | RGB Classic Games
Reply 3 of 7, by legolas77
I have attached the two files, the game has crashed even with your advice.....
    stdout.zip
    5.13 KiB
    27 downloads
    the file1
Reply 7 of 7, by MrFlibble
I looked at your stdout file. People with more knowledge than I might help you, but what you could try doing is:
- force DOSBox to use normal core instead of dynamic
- try turning off sound and music and see if the game is more stable
None of this might work though.
As a DOSBox alternative, you could try playing the game in 86box with FreeDOS installed, here's a brief guide to set this up.
