First post, by OSH
Hi all...
I have an ISO full version of Ecstatica 2. And I can't force this game to run under GUS-emulation. First, I describe my problem:
I've mounted ISO, then I try to run "ultramid.exe" and after "install.bat". The installation starts, and the installer ask me about my music card. I answer "Gravis Ultrasound" and the installation is continued. Everything runs ok. After installation starts intro and I see message "integer divide by 0, error R6003". And the game hangs...
I've read posts about this error, but in my opinion, this error isn't caused (in this game) by too high cycles, but by GUS-emulation. When during installation I set Soundblaster as my music card, everything runs ok. It doesn't matter or I set 2000 cycles, or 30000 cycles - everything runs ok.
I can't understand this, has anybody here forced this game to run under GUS-emulation?
Reply 1 of 6, by MiniMax
Rank Moderator
Moderator
Try disabling all the other sound devices in your DOSBox config.
_________________
Reply 2 of 6, by OSH
That doesn't help.... sometimes I hear sound at begin, but after this the game hangs...
Reply 3 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
wrong IRQ?
1+1=10
Reply 4 of 6, by OSH
Maybe, but I've tested all IRQs - without success. Has anybody hereforced this game to run under GUS?
Reply 5 of 6, by KainXVIII
Can i bump this thread? Because SB support is bugged in this game (crackling and popping ingame, but intro is fine, strangely)
Reply 6 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
No you cannot bump this thread.
Necroposting in a nine years old thread is very bad and necroposting just because it is about the same game is even worse.
This thread was about Ecstatica 2 and GUS emulation. You have a different problem.
Thread locked
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
