First post, by MAN0
Hey all!
I finally got to play ph2 on vista with dosbox and when I swap to 2nd disc, it gives me an extension error (during the intro).
Here's what I do:
Right after it asks for 2nd CD, I unmount the 1st .iso (phantas1) with Daemon.. and mount the 2nd disc (phantas2) and then hit continue.
And about after 15secs it freezes and I get an extension error.
Am I doing something wrong??
Thx
Reply 1 of 13, by laffer35
When you have changed ISO's, you need to hit CTRL+F4 in Dosbox to make it register there's a new CD in the drive 😀
Reply 2 of 13, by MAN0
Thanks for the fast reply my friend! I'm gonna try it and come back on this!
Reply 3 of 13, by MAN0
Alright, it works!!
Thanks again m8!!
Reply 4 of 13, by MiniMax
Rank Moderator
Moderator
If you want to you can certainly use Daemon Tools to mount the images, but remember that DOSBox can also mount images directly:
imgmount X "Y:\path\to\your\image1.iso" "Y:\path\to\your\image2.iso" -t iso
Again, just hit CTRL-F4 to have DOSBox access the 2nd image. And CTRL-F4 to go back to image1.
_________________
Reply 5 of 13, by MAN0
The second command with the -t iso, is to unmount the image right??
Nice tip btw thanx!
Reply 6 of 13, by MiniMax
Rank Moderator
Moderator
unmount???
_________________
Reply 7 of 13, by MAN0
My bad, got it now!
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
Does it work under linux?
Reply 10 of 13, by Reckless
I know that round here that DOSBox would be answer to all ailments (it is a DOSBox forum after all) but the op did said he was running under Vista so the installer is likely to be of use. I personally use the 'best' tool for the job and for a Windows PC running this game, I'd say it is the installer.
Reply 11 of 13, by wd
Rank DOSBox Author
DOSBox Author
So dosbox doesn't work under vista?
Reply 12 of 13, by MiniMax
Rank Moderator
Moderator
Only 95%.
_________________
Reply 13 of 13, by wd
Rank DOSBox Author
DOSBox Author
95% vista? that's almost 100% for sure!
