First post, by Aku-Aku
I use DOSBox 0.72
When i run TP55 i can't use the mouse, although it would be good for me.
Could anybody give an advice how should resolve this problem?
I tried to find information about this subject but was unsuccessful.
Thanks in advance.
Reply 1 of 13, by wd
Rank DOSBox Author
DOSBox Author
Mouse works fine ever since for me with tp6 or tp7x or bp7.
Maybe try some game to see if the mouse works at all.
Reply 2 of 13, by Aku-Aku
That is OK, but i use TP 5.5
I played with Wolfenstein 3D and mouse works fine.
With TP55 mouse still not responding.
I read the readme, faq, forum threads but there isn't answer why, and how should setup to work.
Reply 3 of 13, by wd
Rank DOSBox Author
DOSBox Author
Maybe reinstall tp (within dosbox, that is) and have an eye on the configuration
settings if the mouse support has to be enabled or so.
Reply 4 of 13, by Aku-Aku
I did the reainstall.
Nothing happened with mouse. Had an eye on config, but only filetransfers appeared.
Reply 5 of 13, by wd
Rank DOSBox Author
DOSBox Author
Maybe get tp7 then, might even be available for free download from borland.
Reply 6 of 13, by Aku-Aku
Thanks for the advice.
As i stated i want to use TP 5.5
Reply 8 of 13, by Aku-Aku
Initially i didn't use.
But i know there is an option to use that key combination.
So, i used that and the pointer disappeared.
Used again that is reappaered.
But didn't help anyway.
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
don't see anything that tp5.5 can do that 7.0 can't
Reply 10 of 13, by wd
Rank DOSBox Author
DOSBox Author
Btw. tp55 has no mouse support at all it seems.
Reply 11 of 13, by Aku-Aku
This is the background situation.
My daughter learns to programming in the high school.
There everybody have to use TP55. If she uses anything else IDE that will be disadvantage for she.
They can use somehow the TP55 with mouse support.
This is the reason why i'm searching for a solution for home usage.
Now i am close to resign, if nobody can't help me.
Anyway i am grateful and i thank to the community all the help.
Reply 12 of 13, by wd
Rank DOSBox Author
DOSBox Author
Maybe they use a special version of tp5.5 or not tp5.5 at all.
Ask them if you can use their version, tp5.5 is available at the borland
page as well so that should not be a problem.
Reply 13 of 13, by MiniMax
Rank Moderator
Moderator
FYI: Download link for Turbo Pascal 5.5
http://dn.codegear.com/article/20803
_________________
