First post, by Napstr
Hi This has probably been answered thosands of times and I'm sure I have seen it - but as usual can't find it when I want it.
I am trying to install a program from inside dosbox which installs off multiple floppies - 1 after the other all in the install sequence - is there any command to get dosbox to recognise the new disk whilst still running the install in the background as such so I can change disks and it be recognised?
