First post, by crannation
Hi, I've just started fooling around with DOSbox, and I've officially hit my first problem that has left me completely stumped. When I run SimCity 2000 It works fine for about 20 seconds, then I get this error-DOS/4GW Professional fatal error (1000): transfer stack overflow.
I'm running DOSBox .72 on OS X 10.4.11 on a MacBook 2 GHz Intel Core 2 Duo with 4 GB 667 MHz DDR2 ram. Anyone run into this issue before?
