Alright.
So, I reseted the config file and still no sound.
I have read your 60 seconds guide, and I have done everything like it says there. Dyna Blaster doesn't have a setup/install file for sound/music configuration.
I have also read the readme file. I changed core to normal and fixed the cycles at 2000, and yeah, there's sound now. That's great indeed, although I don't get one thing. Quoting from the configuration file (dosbox.conf):
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate. […]
# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# You can also let DOSBox guess the correct value by setting it to max.
# The default setting (auto) switches to max if appropriate.
I guess auto definition would do the thing, which is the original definiton of the file when you download DOSBox, correct? According to what is written in the file, auto definition 'guesses' the needed definitions, right?
Edit:
Now, I have restored the default settings, core on auto and cycles on auto and there's still sound, 🤣. 😖
