First post, by CombatGold1
I'm trying to play Road Hog in DOSBox, but I keep getting the message "Error opening file ROAD.CFG".
I tried the same set of game files on a Windows 98 VMWare, and it runs fine without such a file in existence.
Just wondering if anyone else has had this, and knows of a solution.
Thanks,
Adam Reece.
Reply 1 of 18, by rcblanke
Run setup.bat ?
Reply 2 of 18, by CombatGold1
Yeah I did. It detected and tested the sound stuff fine, it's just running the game that doesn't work.
Thanks,
Adam Reece.
Reply 3 of 18, by rcblanke
Strange, setup should create ROAD.CFG . Make sure you have writing rights in the game folder.
Reply 4 of 18, by CombatGold1
Just did "attrib -R" to ensure nothing in there is read-only, and NTFS security is all inherited so I have write access... :s
Edit: Could I try your road.cfg file?
Thanks,
Adam Reece.
Reply 5 of 18, by rcblanke
Ok, then I can't think of anything other than a mounting issue; did you install your game in DOSBox? If not, please do so, and keep your mounting settings the same prior to running the game. If that does not work, I'm out of ideas, sorry.
Reply 6 of 18, by CombatGold1
Yep I did. I've tried both from my original floppy disks (the dual-disk full version) and another from some abandon-ware site, neither worked.
Thanks,
Adam Reece.
Reply 7 of 18, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Do a 'echo asdfghj > test.txt' in the directory to see if you can write.
1+1=10
Reply 8 of 18, by CombatGold1
yep that worked, used "type test.txt" to print the result of the file.
Thanks,
Adam Reece.
Reply 9 of 18, by rcblanke
Reply 10 of 18, by CombatGold1
Thanks, saving that file worked 😀
Although I get another error now: "HISCORES.HSC" not found :p
Edit: Solved this by creating a blank file. It then complained it couldn't read offset 1700something, so I just added plenty of spaces and now it works. The same happened for "CUSTOM.HSC", same solution.
Really looks like this game is having trouble writing to the DOSBox hard disk.
Thanks,
Adam Reece.
Reply 12 of 18, by HunterZ
In which directory/folder/path on your real filesystem is the game installed?
Reply 13 of 18, by CombatGold1
DOSBox drive C is mounted to "C:\Documents and Settings\Adam Reece\My Documents\My Applications\DOS Box\HDD".
Within that HDD folder, it then goes "\Games\Roadhog".
Attached my DOSBox configuration in case it helps.
Thanks,
Adam Reece.
Reply 14 of 18, by HunterZ
Interesting, I didn't know that you could mount relative paths in DOSBox. I've always mounted absolute paths (e.g. mount c c:\users\public\games instead of mount c games). I don't like having programs stored under my Documents and Settings folder though - it seems as backwards as having documents and settings under Program Files :p
Reply 15 of 18, by CombatGold1
Yeah it works fine, I don't think it works with the Ultrasound path though. Although I don't use Ultrasound much, I seem to remember some error when I tried using a relative path.
heh I only keep applications/tools in there that are for me only, and don't require installers -- which are all very small applications.
Thanks,
Adam Reece.
Reply 16 of 18, by rcblanke
CombatGold1, this is indeed a DOSBox issue. The cause of the issue is known by the devs and a fix has already been made. Thanks for reporting!
Reply 17 of 18, by CombatGold1
Cool beans. Perhaps I should get an SVN release of DOSBox to get the fix earlier.
Thanks,
Adam Reece.
